#11 |
Moderator
well went for a thrash in mine today
the pedal does have some travel but the brakes bite right at the top - i would say 5-10mm movement if that if i press it to clear the servo its rock hard and at the top of the pedal
__________________
the Red Baron "its a fast Fokker" |
#12 |
Infrequent Poster
mine has this travel issue, went a sat in to other clio 197s and they were the same, even when the engine is off there is still travel, however when you kneed the breaks there good, pedal stiffens ect. ive gotten used to it now.
#13 |
Mine do this too but its not something I have ever thought about. Im pretty sure its normal. If you think about it if you wanted the brakes to bite as soon as you touch the pedal then the pads would have to run on the discs surface. Obviously they dont ap this would cause additional friction n excessive wear. The only thing I can think is that you have driven another car with crazy levels of servo assistance which make you think the brakes are more effective than they actually are. The problem with that is it takes away any feel and feedback. With the clio the harder you press the brake the quicker you stop, I have driven cars where very little changes - they are either on or off. I really dont think its a problem unless you have a few inches of travel.
__________________
Liquid Yellow R27 No. 184/500 - Its all yellow!? Perfect for driving round the Nürburgring (next year...) |
#14 | |
Infrequent Poster
Quote:
I have purchased some AP Racing - Dot 5.1 Brake Fluid and I am going to bleed the system through, will post here how I get on, as at the minute I have about 2-3cm Travel. |
#15 |
Infrequent Poster
press em hard do they work ?
Try a Porsche lol, you really have to push the pedal to get the brakes to work. |
#16 |
Infrequent Poster
Bled the brakes today, not much of an improvment, it must be meant to have a bit of travel, or is there a way of adjusting the brake pedal itself?
#17 | |
Moderator
Quote:
have you tried pumping the pedal really hard and working the handbrake to make sure the rear calipers have adjusted up
__________________
#18 |
Infrequent Poster
do you mean pump the pedal and work handbrake whilst bleeding system mate?
#19 | |
Moderator
Quote:
if the brakes are bleed is the brake pedal hard ? have you had the front & rear pads out - cleaned etc ?
__________________
| Thread Tools | Search this Thread |
| Display Modes | |
