225 throttle body on 250 inlet help
Right as some will know I have a 250 engine in my 197 and I'm currently putting a 225 throttle body on to the 250 inlet. I've had an adaptor plate made but now I need to swap the plugs and unfortunately I'm no electrician so any help would be great. I've been sent this but means nothing to me
Pin 1 = G4
Pin 2 = G3
Pin 3 = M4
Pin 4 = M3
Pin 6 = D3
Pin 5 = G2
Easy enough, just need to move the corresponding pins. DBW throttles will almost always have motor control +ve and -ve , and 2 TPS sensors, sharing a +Ve and -Ve and then separate wipers (signal wires) - That's your 6 pins.
Can see pin 1 & 2 are thicker so they will be your motor control, the rest can be pinned out with a multi meter, however...... I have the wiring diags below! :wink:
Megane III wiring:
Megane II wiring:
Reactions: M77MWw
@M77MWw I saw your post about the DBW unit not working, so I double checked the wiring diags I have. The Megane II 'sport' TB should be the diag below. - I had to get some later software for this as the copy I had lists an F4R...but digging in to it and it's for the F4R-771 - which is some random 135bhp Megane or something?!
Any way R26 uses the F4R-776 which this later software has, here's the wiring:
