Car Stereo Installation Help
Hi,
I am looking to change my standard cabasse car stereo to a more up to date unit. Only trouble is I have the Cabasse cd changer where the Car Stereo should be so it will need rewiring as the amp is under the drivers seat and have no idea where the iso leads are located there. Any advice would be appreciated.
thanks
Andrew
if it a 197 Clio everything is in the dash slot area I retrofitted your Cabasse two part unit into my 197 all that is different is there is a small loom that links the under seat part to the head unit but everything is there unless you have factory built in Bluetooth other than that it's still standard behind the dash head unit.
