Clio 200 suspension on a 197
Discussion in 'Suspension, Brakes & Steering' started by 6705russell, Jul 17, 2017.
  1. 6705russell
    6705russell Paid Member
    276
    Staffordshire
    Clio 197
    Ok so I managed to bag myself some shocks and springs from a 200 Cup and the seller said they were the larger top mounts and would fit the 197 so I could do with someone telling me if they look about right? Also I notice it looks like a nylon ring has broken away on the bump stop (if that is what it is?), will this need replacing? Apologies for dumb questions but worked on the suspension before on these...
  2. 6705russell
    276
    Staffordshire
    Clio 197
    Can anyone advise?
  3. 6705russell
    276
    Staffordshire
    Clio 197
    Swapped my standard set up for the cup shocks and springs, if anyone is thinking of doing this themselves don't bother, take it the garage and let them do it, never again!
    sevenfourate likes this.
  4. sevenfourate
    sevenfourate Devotee of OCD Paid Member
    Lowestoft, England.
    Racing Blue RS-200
    There speaks a man of my own heart.
    You dont buy meat from a dentist. And you don't get a gardener to plumb in your new washing machine......
    If its 'easy' i'll do it. Apart from that i'd rather do some overtime and leave it to the experts.
    Big Ben likes this.
  5. Big Ben
    Big Ben Paid Member
    Herts
    197
    ^^^^ Amen
  6. 6705russell
    276
    Staffordshire
    Clio 197
    I started at 8.30am and finished at 17.00, tackled the drivers front first and that was the worst, I used spring compressors to fully close the spring in and take the whole unit out, once the unit was out it was just the simple job of undoing the top mount nut and taking the top mount off so I could release the springs....that was until the top mount would not come off and I put that much force on it the thread fractured all the way down so then it was the angle grinder through the spring and shock piston!
    must say though the rears only took 40 minutes!
  7. Antti O
    Antti O Paid Member
    Mikkeli, Finland
    Clio 197 Ultra red 2007
    Did you have air impact or battery impact gun? It sounds weird that shock nut which is securing top mount is so seized?
  8. Car.crash
    Car.crash Paid Member
    101
    Clio
    These jobs arnt overly hard, issue is people attack them without the right tools and get stuck.
    No impact guns, No Swan neck spanners and struggle to remove the top nut.
    Not saying this was the case with the op but in general that's where most people get stuck.
  9. 6705russell
    276
    Staffordshire
    Clio 197
    No i did not have an impact gun, I had the correct swan neck spanner the problem was the thread was corroded so when I put the allen key socket in it was just rounding off inside..
  10. link
    link Gold Member
    148
    Clio 197 RB
    I would have probably suggested undoing the top nut first, jacking the car off the ground so the strut is under full strain usually helps... That and a healthy dose of WD40 etc. :thumb:
  11. 6705russell
    276
    Staffordshire
    Clio 197
    Tried both methods, it was because the allen key hole had rounded in the thread. Sorted with the angle grinder straight through the spring and piston then put the left over piston in the vice and got the nut off with a big breaker bar.
  • Share This Page
