Clip gurus
R27WTF
Any clip gurus on here can you help with turning someLights off?
My dash is lit up like a Christmas tree
Need the airbags off, and remove the abs light etc (I’m Not running abs)
You will need the traction control disabled as well the only guy I knew was ALS Performance but he is in Carlisle but any of the Clio cup or people that prep them can sort it or if you got a Renault clip someone could remote control it with team viewer and do the changes. Dealers will not disable safety systems encase they get sued I thought there was a Renault specialist in your part of the world. I remember talking to ALS one day he said about removing the traction/ steering angle system as the cup cars hit the apex hard and the kerbing impacts and cause the traction to kick in.
Ye I want to remove the traction control save me having to turn it off. I’m hoping Iv made the right choice in removing the abs now
A lot of the guys racing Impreza's are refitting ABS mainly due to the disadvantage in the wet. I found I could not brake as late as ABS equipped cars in the wet for fear of locking up in the dry it wasn't an issue.
Reactions: tombate911
Iv not removed the abs wiring if left it in for now and kept the pump so worst case it can be added back in if needed
Reactions: Arch
