Floor Plate
I have bought a carbon footplate for my Clio 197.
Plan is to attach this to the raised box section on the driver side.
However I think I will also need to put supports under the 4 corners of the square so that they can take the load of me standing on it - putting weight on it etc...
How would you do this?
I thinking about legs with rubber feet or brackets - not sure...
Just get some bolt sleeves and cut to the required length and nut rivet the floor pan. Bolt goes through the carbon footplate in through the sleeve and into the nut rivet to secure.
