Gear oil change
Discussion in 'Engine, Gearbox, Exhaust and Air Intake' started by Steve wright, Oct 22, 2017.
  1. Steve wright
    Steve wright Paid Member
    89
    Lancashire
    Car:
    1M BMW / Clio 200 Cup
    Is it straight forward drain and top upto a level plug or do I need anything else. I will use the red line oil recommended.
    1st gear is a little difficult sometimes not sure if clutch is adjustable I've not looked yet. Can't harm to do the oil .
  2. Barney626
    Barney626 Winner - POTM December 2017
    527
    Loughborough
    Car:
    Clio 197 - Nimbus
    Just did mine today, assuming the gearbox for the 197 is the same as the 200. Has a drain plug with an 8mm socket on it and the fill port has a white plastic wing nut on it.
    Steve wright likes this.
  3. Pav
    Pav Moderator
    11,237
    Manchester
    Car:
    albi blue 197 with boost
    yeah as above..you will access it from the passenger side..
  4. Steve wright
    89
    Lancashire
    Car:
    Is it two bottles of the MT90 I need .
  5. JMR
    JMR Paid Member
    184
    Notts/Lincs
    Car:
    Porsche + LY200
    Mines getting done on Friday.
    Have we had any improvement in slickness of the box getting into 1st when cold fellas?
  6. Barney626
    527
    Loughborough
    Car:
    Clio 197 - Nimbus
    I used MT-90, not sure what was in it before.
    Definitely smoother all round. Not a huge difference but there. 2nd seems to have benefited most for me. That and 4th were my problem gears.
    Honestly, cold is still pretty crap but that doesn't bother me tbh. Just give it a minute after starting and it seems to make getting gears in easier.
  7. RJH_197
    RJH_197
    9
    Car:
    Clio 197
    IMG_2122.PNG Sorry to hijack your thread,
    Can I just clarify if this is the correct redline oil to use for my 197? When it was first mentioned to me it came up as automatic transmission fluid but after some research I found the above?
  8. Barney626
    527
    Loughborough
    Car:
    Clio 197 - Nimbus
    I used redline mt-90.
    Same bottle but different label.
  9. RJH_197
    RJH_197
    9
    Car:
    Clio 197
    Cheers, I assume this is it and that I do need 2 of these bottles
    Gus likes this.
  10. Barney626
    527
    Loughborough
    Car:
    Clio 197 - Nimbus
    Thats it, 2 is just enough to fill the box.
  11. Pav
    Pav Moderator
    11,237
    Manchester
    Car:
    2 bottles mate :thumb:
  12. -Eddie-
    -Eddie- Missing In Action Paid Member
    2,257
    Belfast
    Car:
    200 Cup
    Bit of a thread revival. Is 75w90 definitely the correct gear oil for these boxes? I thought the standard Renault Elf oil was 75w80.
  13. Foxspeed
    15,509
    Car:
    ford mustang shadow gt v8
    if you go 90 it can give a poor shift when cold
  14. Doogle
    556
    Plymouth
    Car:
    BMW e46 330cd
    Sorry to hijack, is this an easy DIY job? I havent seen a how to but not to say there isnt. Likewise, as above, is it not worth just using fresh Elf oil?
  15. tcw
    tcw Paid Member
    173
    Chelmsford
    Car:
    Clio 197
    It's really not hard - 8mm square bit for the drain plug. Always check you can remove the fill plug first.
    Changing to the Elf oil is better than not changing it at all. 2L is enough. Fill until it's level with the fill hole - you can either pump it in or use pipe to make it easier.
    wootwoot likes this.
  16. Doogle
    556
    Plymouth
    Car:
    BMW e46 330cd
    Thanks very much, where is the drain plug and fill hole? Ill have a look on Opie Oils.
  17. tcw
    tcw Paid Member
    173
    Chelmsford
    Car:
    Clio 197
    I'd buy Elf from Renault Parts Direct initially, get it done, then do it again at some point with more expensive stuff if you'd like.
    Drain plug on the bottom iirc and fill hole right next to passenger driveshaft - it's white, looks like a wing nut type thing.
  18. Foxspeed
    15,509
    Car:
    theres a how too on the site
    Doogle likes this.
  19. Doogle
    556
    Plymouth
    Car:
    BMW e46 330cd
    Ill have a looksie.
    Ive been looking around at Redline stuff, they changed from 70w80 to 75w80. First number is for cold temps, is the 70w80 better therefore for our gearboxs and the not particular warm British winters? The 70w80 is still available in places to buy, Opie only do 75w80 now.
  20. Andrei C
    Andrei C
    1
    Car:
    Renault Clio MK3 RS 200 .
    Hello Guys ,
    After how many miles Renault recomand to change the oil in gearbox ? Thank you in advance !
  • Share This Page
