help
Roy
clio197.net legend
got in the car earlyer and the radio will not turn on
the time and temp display is on and wont go off when
you get out of the car any ideas will this drain the battery over nite??
Strange! You tried using the card? Sounds like an ignition feed problem.
whn you double lock the car does it go off? the radio should turn on no matter if the car is started or not (or even ignition is on). try turning it on without doing anything but unlocking the car and see what happens - otherwise try a new battery as Adrian says its a symptom
tried this morning no good everything else fine will try fuse when wife brings it back tonite
fuses checked all good
wife said auto lights came on and the dash lights didnt aswell tonite:huh:
Oh dear. Sounds expensive! Cold weather playing with dodgy french electrics! Disconect the battery and leave it for a few minutes, then reconnect it. Just make sure you have the radio code.
Great news mate! Glad it was something simple mate. So which one had gone?
Lol, no worries mate! I was just interested in what blew what and why! Lol! It's fixed, so that's all that matters!
