My 200 will not start
Discussion in 'Engine, Gearbox, Exhaust and Air Intake' started by lordpercy, Jun 14, 2018.
  1. lordpercy
    lordpercy Paid Member
    46
    North West
    Car:
    Renaultsport Clio 200
    When trying to start, it makes a clicking noise, the info screen says ‘steeeing not locked’
    The AA managed to get the car started my linking out Negative on the Battery to the engine block metal work, so he suspects the engine earth may have failed..
    Can someone explain where the earthing Point for a 200 would be located? It won’t start since I have got it home.
  2. G8RSH
    G8RSH Winner - POTM April 2018 Paid Member
    506
    Devon
    Car:
    FF GW 200
    The negative from the battery is located above the acoustic valve on the right hand side of the bay.
  3. lordpercy
    46
    North West
    Car:
    This one?
    I’ve cleaned that up, is there another earth strap that connects to the engine/ gearbox?
  4. link
    link Gold Member
    304
    Hyrule
    Car:
    Clio 197 RB
    Here's all the connections on the engine loom, check the two big earth cables which go the battery at either end first...
    Looks like one end bolts to the gearbox (MH)
  5. lordpercy
    46
    North West
    Car:
    Wow, that’s for that!
    I stripped it down earlier, and found both earthing points. Going to clean them up and try firing the car up again.
  6. Liam Gunby
    Liam Gunby Paid Member
    77
    Nr Loughborough
    Car:
    clio 197 2008
    Have you bump started the car?
    Im currently in exactly the same situation with my 197.
    I have bought a new starter motor because it bump started and ran fine then, until i turned it off then wouldn't work again with same error 'steering not locked'
    If you have any other GEN on it let me know please because if its not the starter motor i am stumped.
  7. lordpercy
    46
    North West
    Car:
    Liam, it was the battery! I put a new one in on Saturday, cleaned up the earths etc and its been fine since.
  8. Liam Gunby
    77
    Nr Loughborough
    Car:
    clio 197 2008
    Did you volt check the battery before you got a new one?? Because I did this and it was reading 12.5v. :/
  9. Northloopcup
    Northloopcup Gold Member
    509
    Car:
    AG 200 FF
    You can have 800v, but if it ain’t got the amps it won’t do fuck all mate. Voltage just pushes the amps in simple terms, so if it has no amps, you have no current flow.
    suj likes this.
  10. Liam Gunby
    77
    Nr Loughborough
    Car:
    clio 197 2008
    I dont like wiggly amp things. Try to stay away from electrons haha. I did get a shock from the starter when I moved the heat shield so I know theres some form of power to the starter....
    twonk likes this.
  11. Dumdum
    Dumdum Gold Member
    59
    Car:
    Renault Clio RS200 CUP
    You simply didn’t unless it was static built up on your clothes
    Northloopcup likes this.
  12. Liam Gunby
    77
    Nr Loughborough
    Car:
    clio 197 2008
    not me personally got a shock but i moved the heat shield and it sparked alot. i did forget to remove the battery connection tho.
  13. Dumdum
    Dumdum Gold Member
    59
    Car:
    Haha yeah that will do it, just whip the earth off the battery next time
  • Share This Page
