cam kits are around £150 - look at the site traders on here - they come with the rear cam seals
as for the "cam gear" - you mean the dephaser pulley on the inlet cam - if it has free play in it it needs changing if not then its fine
specialists usually do the job for around £500 - the 197 is alot easier than than the 182 to work on
