progress of R80 CUP- now with boost
last weekend did a bit of wheeling and dealing.
so now running a set of.
they need a clean like the rest of the car and also need some black tpi bolts
Still looking into it but first thoughts are bent a rod or span a shell and knackered crank. It didn't sound healthy
well this is back on the road again had it back a couple of weeks now just putting some millage on it. A few parts changed, another r26 engine with a lot less miles on the clock. fitted 630 injectors and a larger decat to back box exhaust. had a seal leaking on the gearbox so that was changed at same time. But she drive so much nicer and quicker than the last engine. and an added benefit is all the liquids are staying in the engine this time.
ill get some better pics when i wash it.
power it made the graph i have shows 284 bhp a couple of days previous it made 303 but lower torque. so not entirely sure but as [MENTION=193]MikeLYR27[/MENTION] and @Fernandez will tell you it goes well. had a little play with angel on tue and we were neck and neck so either mines making a little bit more power or his is making less.
so had a slight issue of hitting a pigeon at a silly speed. totalled the headlight so had to order a new one. didn't get a picture of new one fitted.
