Universal Bucket Seat Mounts
av4625
Does anyone know if a mount like this will work in a 2006 clio 197 and still be in the center of the wheel?
The whole subframe and sidemount route is quite expensive (maybe thats the only way, I don’t know).
I saw rentune do a set like the ones linked, but are much more expensive. From looking at the photos it looked like one side is bent more than the other on the rentune ones. (Maybe to keep the seat in the middle, but hard to tell from the pics).
Is it possible to keep the belt buckel?
Any help is appreciated, I’ve never put buckets in a car before.
https://www.motamec.com/motamec-ste...-universal-fits-sparco-omp-with-stickers.html
Reactions: alliemam197
I don’t think universal mounts would work. They would be too low and off center. You would need something like the sparco subframes and side mounts or base mounts on top.
Or the rentune or SW motorsport side mounts that go straight to the floor
I may have some sparco subframes and side mounts for sale soon. With high tensile bolts and normal seat belt buckles to go with them.
Awesome. I got sparco subframes and sidemounts from some guy on here and everything fitted with sparco sprint seats from GSM
I sell Both subframes that you can mount your own side mounts and seat to.
I also offer direct fit side mounts in ally that are a direct fit I believe we are the only ones to do these in ally 828a4dc54c0fd7f24003d824a076a028.jpg
Won’t these sit really high? Have any pictures mounted
No, the clios need off centered high sidemounts to get the height right. You cant just use "universal" sidemounts. I had sparco subframes which fix the off centered part then put universal sidemounts on top. but it was a bit of a pain when taking the seat in and out as there are so many nuts and bolts holding it together. I then went for the SW motorsport tall sidemount which are a bit like the supreme ones above. They are much handier
Reactions: TrackM3
