Blown shock after <5k miles?!?!
Discussion in 'Suspension, Brakes & Steering' started by Sherlock101, Sep 16, 2018 at 3:59 PM.
  1. Sherlock101
    Sherlock101 Paid Member
    50
    Oxford
    Car:
    Clio 200
    I fitted new front shocks to my 200 (full fat w/ cup pack) in June, and have covered a few thousand miles since then. Today I took the car for a drive after a weeks holiday to make sure everything was ok, and when I got out I noticed a fluid on the inside of the drivers side wheel. On closer inspection I found oil all over the shock and covering a lot of the wheel well! I didn’t hit any potholes on my drive today, so did I just get sold a dodgy shock? It was bought new!!
  2. Dumdum
    Dumdum Gold Member
    506
    near mansfield, notts
    Car:
    Renault Clio RS200 CUP/fiat ducato campervan
    you get faulty parts from anything, that's what a warranty is for, return it to Renault parts direct or take it into a Renault dealership for a free labour and parts warranty (providing they don't find anything incorrect with your fitting obviously)
    Peugeot used to offer this service with genuine parts as long as it wasn't an issue with fitting... ie your fault... not sure if Renault offer the same, but id presume so...
  3. -Eddie-
    -Eddie- Missing In Action Paid Member
    2,257
    Belfast
    Car:
    200 Cup
    As above. You’ll get parts warranty (for 12 months) so long as a manufacturing defect can be identified.
    Not sure how it will work with a shock though as Renaults repair method says both should be replaced.
  • Share This Page
