Hi Gents,
have noticed that my car shoots a bit of blue smoke on full throttle high rpm, but zero on general driving. The oil consumption is high around 500ml every 300km. Initially thought it was the PCV on the throttle (The idle was all over as well). After changing it the oil consumption is a little better and the idle is perfect, but still spot a bit of blue smoke on high rpm, just shoots a bit and then clears out.
Any ideas? Should i do a compression test? Characteristics don't seem like rings or valve stem seals, but then again im not familiar with these engines.
