Quick and easy way is to disconnect the vacuum pipe going into the solenoid at the back of the valve ( this stops it opening ) keep the valve in place and run a cold air feed down behind the light and curl to wards the bottom grill. I brought VC001R ( think R means red ends ) viper pipercross 65mm cold air feed pipe, its about a meter long, i painted the end on mine matt black with the intention of drilling a hole in the black plastic panel to the side of the radiator, buy managed to wedge it between the plastic panel and the grill just incase i had any adverse effects. Ive had none. Ive also got pipercross panel filter, silicon hoses, tape the holes up on the pipe to the front grill, and cut off the plastic box the is around the grill inlet behind the front grill. Even thou ive a after market exhaust, low revs i can hear the induction noise. It will be a bumper off job thou.
