Constant issues
Sorry if I have posted this in the wrong place...
However I am hoping someone can help. Having an absolute mare with my Clio 197.. So this evening both of my headlights and sidelights decided they just didn't want to light the way for me anymore (I still have full beam and fog lights) oh and noticed the other day I didn't have reverse lights, so I change the bulbs and OH LOOK they still don't work...
My passanger window has also decided to give up on life and has stopped working too!! yes iv changed the fuse after completely ripping out the dash..
Can an someone please recommend anything... I'm at the end
There are two fuse boxes. One under the steering column and one in the engine bay under the 2nd intake trumpet. Also check for blocked drainage holes under the scuttle panel. I recently learnt about this and heard it can cause a world of problems with electricals.
Check for water ingress in both. More likely to be in the bay but you never know inside!
It's probably your fuses mate.
I had an issue months ago where my hazards didn't stop going off, however that's stopped but since then it's one thing after another..
2nd intake trumpet... Right okay!! Thank you
Drainage holes are a good shout but if it's that it sounds like the damage is done, if they are clear at least you could rule that out. I know that the 172s suffered with wiring gremlins, perhaps take it too a specialist in auto electrics. At least try the drainage holes first it's an easy check to do yourself.
My reverse lights had just stopped working too . Just bought some new bulbs wAs going to try that first . Could blocked drainage holes stop them from working too ?
