FAO PS4 & Xbox one owners.
M
Mentalpen
Firstly PS4 Owners.
****EDIT**** seeing as how the links are dead an no mirrors i'm guessing this is now BS
  1. ______ _ _____
    | ___ \ | | | _ |
    | |_/ / ___ ___ | | __ ____ | |/' | _ __
    | / / _ \ / __| | |/ / |_ / | /| | | '__|
    | |\ \ | __/ | (__ | < / / \ |_/ / | | 2011-present
    \_| \_| \___| \___| |_|\_\ /___| \___/ |_| twitter.com/Reckz0r
    "Buy an Apple, Microsoft, LG, Samsung, Nintendo..but don't buy a Sony." - George Hotz
    I have been away for a while, so my question to you is; did you miss me? I am aware that ya'll were all thirsty for a cup of a fine Reckz0r release, so here I am...with a fine ****in' glass of a RECKZ0R release, yeaaaaaaaaaaaaaaaaaah! (did that sound sarcastic?)
    Before I get off started ridiculing Sony, I'd like to pay homage to Sir George Hotz, who looked into the eyes of Sony and made them ejaculate as they bowed down in fear. Very artistic of you, Geohotz.
    Now that, George Hotz has resigned from engaging in all types of sexual activities with an computer, and as all fans of PlayStation are crying for the comeback of GeoHotz..I'd let you all know, you don't need that lil ****in' faggot. You really don't.
    Well, alright....LET'S GET STARTED ALREADY!
    As you all know, PS4 runs Orbis OS, that is highly based on FreeBSD (which is a opensource operating system), and as the PS4 is closely identical to a PC, I guess you all knew that PS4 and the Xbox One will probably end up getting pwned soon, and now..its time.
    NOTE: I did not find this vulnerability within PS4, nor did I write the exploit, while I was browsing thru an Brazilian console-hacking forum known as condinh0 (I am sure you all know this if you hang out at TOR). A person named x-s4nd3r released the devkit of PS4, as well as the exploit within 5 days of PS4 release. Although most of you don't know how to apply that jailbreak on the PS4, I am making this tutorial to sort this **** out for you.
    -EXPLOIT DETAILS-
    OS: Orbis
    Console: PlayStation 4
    Type: Privilege Escalation/Buffer Overflow (allows to run assigned code)
    Created on: 25 November 2013
    -AUTHOR-
    URL: http://twitter.com/xs4nd3r (feel free to get him v&)
    FILES:
    PS4 DevKit: https://depositfiles.com/files/deitivkle
    Jailbreak Package (exploit): https://depositfiles.com/files/xwurigoq
    ***IMPORTANT***** - You need the DAY ONE Update to jailbreak the PS4, otherwise these files will be considered unrecognizable.
    GUIDE:
    1. Create a folder on your USB storage device. This is where you'll put the exploit.
    2. Create a "SANDERPS4" folder. Inside that folder, create another folder named "EXP."
    3. Extract the PSORBISEXP.PUP file from the package, and save it in the EXP folder.
    4. Make sure your PlayStation 4 is turned off.
    5. Connect the USB storage device to your PlayStation 4, and press the power button for at least 7 seconds. The PlayStation 4 will start in Safe Mode.
    6. Select "Update System Software."
    7. Follow the on-screen instructions to install the jailbreak.
    8. If your PlayStation 4 doesn't recognize the jailbreaking file, make sure that the folder and file names are correct.
    9. Voila! JAILBROKEN!
    You now have the ability to run unassigned/assigned code and pirated games on your PS4, but do NOT go online, if you do go online, your console will be immediately banned.
    Have fun piratin'
And now you Xbox One owners
Xbox One HDD Tools
What this does
Given any HDD over 500GB in size, you can format it for use with you Microsoft Xbox One console
How
Instructions
All of this must be done as root! I HIGHLY suggest you do this on a livecd or usb booted system if you don't 'know linux' and would rather not wipe the wrong hard drive.
  1. Connect your HDD and take note of what its called (ex: sda, sdb etc)
  2. Run the script with the device name as the first parameter
  3. It will bitch about missing partitions etc, but write a file with commands to create said missing partitions
  4. Run the created script
  5. Copy the correct files to the newly created partitions
  6. Unmount the newly created partitions
  7. Run the main script again
Putting it back together
When you put the new HDD in your console for the first time and boot up, the console will go the the green "Xbox One" screen, pause for a second or two, then shut down. Boot the console again. This time it should pause at the green screen for a while longer, then go to a black screen for even longer. It can take several minutes before anything happens after this, the xbox is automatically creating temporary files during this time. If you copied everything correctly, it WILL go to the dashboard eventually, just be patient!
What is linux?
Wait for a windows version
Required Files
These can be gotten off your original HDD easily
└── [4.0K] System Update
├── [4.0K] A
│ ├── [341M] deltas.xvd
│ ├── [ 36M] SettingsTemplate.xvd
│ ├── [ 24M] sosinit.xvd
│ ├── [ 62M] sostmpl.xvd
│ ├── [267M] systemaux.xvd
│ └── [850M] system.xvd
├── [4.0K] B
│ ├── [ 30M] SettingsTemplate.xvd
│ ├── [ 23M] sosinit.xvd
│ ├── [ 45M] sostmpl.xvd
│ ├── [ 91M] systemaux.xvd
│ └── [761M] system.xvd
└── [ 44M] updater.xvd
I understood 1% of that
Where do I put the petrol in? How much bhp/torques does it have?
lol, i've looked for the ps4 files but can't get them anywhere so i'm calling BS now, last time there were mirrors all over within a few mins.
as for the xbox one post, it's 100% legit :hug:
