Front wing vents
Discussion in 'Body Work and Exterior Lights' started by bedoef, Sep 16, 2018 at 6:10 AM.
  1. bedoef
    bedoef Paid Member
    61
    Dubai
    Car:
    2012 Clio RS 200
    Anyone tried to open those up from the arch liners? Does it do anything for cooling?
  2. Jack Maxwell
    Jack Maxwell Gold Member
    72
    Car:
    Clio 200 Silverstone
    These already serve a purpose of extracting hot air from the engine bay. Here is a quote from the original press release:
    "The extractors visible on the front wings contribute to the car's aerodynamic performance by neutralising the turbulence produced by the wider wings and play a part in improving the model's CdA. They also facilitate the extraction of hot air from underneath the bonnet, while the vents are angled to channel airflow along the sides of the car for enhanced performance.
    Clio Renaultsport 200 is also equipped with an air diffuser, an aerodynamic feature normally only found on high-end sporting cars. Air passing underneath the vehicle is channelled via the flat bottom to the diffuser where it accelerates before being expelled at a higher speed. Combined with the shape of the diffuser, this creates a zone of depression under the car, sucking the chassis to the ground. Compared with a conventional wing, diffusers generate significant downforce without resisting forward movement. On a track, at 80mph, lift is reduced by almost 40kg. The diffuser is designed to function in association with the rear flat bottom which leaves space for the exhaust silencer and lateral-mounted tailpipes."
    Sherlock101 and bedoef like this.
  3. bedoef
    bedoef Paid Member
    61
    Dubai
    Car:
    2012 Clio RS 200
    Strange, they look and feel to me like they are closed off. I have to poke my head in the arches next time the car is on the lift.
  4. Sean197
    Sean197 RIP Albi :( Moderator
    3,350
    Fife, Scotland
    Car:
    Albi 197T - RIP, MK7 Golf GTD Sports Wagon
    Been discussed before, when you take the wings off the vents are blocked off and there's nowhere for air to go.
  5. bedoef
    bedoef Paid Member
    61
    Dubai
    Car:
    2012 Clio RS 200
    Ah sorry, had a look through search but I must have missed it.
  6. harespeed
    harespeed Paid Member
    12
    Car:
    LY Clio 200
    Excuse my naivety but surely you won't see the vent coming from the arch of its allowing air to pass through from the engine compartment?
    Sent from my Pixel using Tapatalk
  • Share This Page
