Hi guys,
I have a small query about removing the topmount from this, the problem is i have bought some second hand v1's which still have the previous owners top mount on which he needs back,
The problem i have is the only way can see of removing the top nut is by using a 9mm on the top and a 18 offset ring spanner however once the nut gets to the top it runs out of space for the 9mm spanner, the nut is then not loose enough to come off still, its very rusted as you can see.
How did you guys manage this? I thought it had more material on top too allow for this?
Thanks G.
Thanks G.
