197 Electric Window Button (Auto Up)
luke197
Hi Guys,
I'm having a bit of a problem with my drivers side electric window, it won't automatically go all the way up. I have tried to do all the different reset options and still no luck.
One thing i have noticed is that the button does not give a second click when pulled all the way back unlike the other switches. Is this normal or do we think its the switch at fault?
Cheers Luke
2 clicks are anti pinch (ei will stop if your hand is stuck in it) and 1 click is not. If the switch is not the same at the other side you req a new switch.
Sounds like I'm after a new switch then. Mines not a cup just a fatty with the cup pack so should have it. Any ideas on the price of a new switch?
