2010 197 missfire
I've got a 197 with a bad miss fire!
plugged the computer in, no faults. Checked plugs, fine. Checked each coil, they're fine. Compression test, was down one 1 and 2. Pulled head off, lapped valves in 1 and 2 in, built back up, still missing! Replaced coil and injector loom, still missing with no faults!
any ideas?
I've had new plugs a few weeks back. I've swopped coils over off another Clio. Still misfired with coils swopped over.
you need to check it out correctly/proper diagnosis than assuming its the same as someone elses fault.....
