197: Best place for belts service? (Gloucestershire)
Can't decide whether to sell my 197 or not, but if i do keep it i'll probably get the belts done soon, its only done 34k but it's a '56 plate. So does anyone know of any cheap places around Gloucestershire?
I guess i'm looking at:
Cam belt kit
Aux belt kit
Dephaser (maybe)
Waterpump (maybe)
What should i be looking to pay £500, £600?
Pretty skint at the minute as my bike engines being rebuilt so the cheaper i can get it done the better!
Ive used SJ Cooks in Bristol & have no complaints. Paid just over £600.
Isn't Bristol Street Motors the dealership in Glos? Ive not found any local independant specialists so unless you fancy a drive...
Renault quoted me £417 inc aux, cambelt kit.
And £540 with water pump. A local trusted garage quoted me £240 without water pump. Just depends wether you want that stamp in your book.
I've been told parts alone are £240!
Cambelt kit - £120
AUX Belt - £20
Dephaser Pulley - £100
So I gotta be looking at £400 at absolute lowest if I can find somewhere cheap locally, don't really know anywhere though.
Cambelt kit - £120
AUX Belt - £20
without water pump done;
parts £163.96 (inc vat)
labour £248.40 (inc vat)
total- £412.36
(parts included in above were; cambelt kit,core plug, plug la and kits courrie axs)
with water pump;
parts £221.80 (inc vat)
labour £318.60 (inc vat)
total- £540.40
(parts included in above were; cambelt kit,coolant,core plug, plug la, kits courrie axs, water pump )
from renault when i went down the other day :smile:
total- £412.36
with water pump;
total- £540.40
Thanks very much, so if I'm doing Dephaser Pulley and not waterpump I'm probably looking at £550.
Bear in mind that the crankshaft pulley is also due on this service.
KTEC quoted me ~£680 for aux & Cambelt kits, water pump, crank pulley, coolant change, oil change & all filters.
Fred @ btm in brum is about 490 for cambelt/aux belt kits & waterpump iirc.
Are dephasers bad on the 197 then? Thought that was just a 1*2 issue?
Car has felt a bit under powered twice this week so had my local Renauit Specialist clip test it and he reckons it logged a dephaser code which he says if the pulley was faulty it could hold the timing back?
I'd be interested in knowing some local prices also,I'm based in between Chelt & Glos but really don't mind traveling a bit.
Guys, just for reference, dont scrimp on getting the belts done on your F4Rs by anyone other than a proper specialist.
Incorrect timing can quite easily lose you 30bhp. Get it done by someone with the correct locking tools, & experience of the engine, ie Danny@519, TDF, Fred@BTM, hell even ktec.
Dont get it done by some cheap garage that in 99% of cases, will bugger it up ...
