Boost guages
What boost guages are people using if any?
I fancy mounting some where the little lcd display is. All it does is tell me the time as I don't have the radio on and as it's a cup there's no thermometer.
Bit overkill mine...depending on what you want.
Also have a scanguage2...that Turbo Guage one doesn't show boost!
Scanguage2 does so so much. Even down to how much fuel costs you and it costs you per trip.
And clears fault codes which I've found a bit useful.
Turbo gauge does all that too and shows boost. The only thing it doesn't show that the Scanguague shows is 0-60 time.
I had mine set to show boost PSI, coolant temp, voltage and air inlet temps.
