brake fluid
I use ATE Superblue, great fluid and as its blue you can see when the system its fully bleed. Only used 1 can. Reasonable price too. Was about £30 from eurospares
ATE and Motul 600 are very popular on here. :smile:
You don't really need DOT 5.1, just check the wet boiling temperature is nice and high.
I use Millers Oils Race Fluid 300+, no issues with that so far and it's ~£13/500ml. I used 3 x 500ml bottles and had a little spare at the end after bleeding.
