Change up 'beep'
Are you supposed to have the change up 'beep' in a 197 or just the light? if so why isn't mine working?
Cheers in advance
No. Just came in the later clocks on the 200. Should get a green shift light though
Find yourself a set of clocks from a 200 and swap them over.
Shift beep will work fine but you'll need to get a mileage correction
The shift beep is a pointless gimmick. Peak torque drops like a lead balloon about 250rpm before the beep comes in.
After you've driven the car enough you don't need the beep as you can feel the torque drop off before it even happens
Coming from a standard Ford Focus, my 197 is the first "powerful" car I've owned, managed to hit the rev limiter once since owning it and never realized how much power was suddenly lost when you do. It almost felt like I stamped the brake pedal as it suddenly stopped accelerating. Odd feeling.
