Fernandez
Gold Member
The moment some have you have been waiting for:
We are pleased to announce a new Powerflex vehicle application listing for the Renault Megane II that includes new suspension and engine mounting products. Many of these parts are cross referenced to other Renault models including the Clio III.
For the suspension we have made adjustable options for the front arm.
On-car adjustable camber bush PFF60-501G fits the front arm front bush. The bush comes with new Zinc plated outer shells, offering additional support, and our uniquely blended high performance black polyurethane with grease retaining bore. The stainless steel on-car adjustable sleeves aids making the geometry adjustments allowing 1.5° of adjustment using the supplied spanner.
PFF60-502G front arm rear bush offers caster adjustment to help with turn in and anti lift properties giving additional traction. The new anodised aluminium outer shell supports the polyurethane bush, the adjustment coming from stainless steel offset sleeve giving 0.75° extra caster.
The available suspension bushes are (please click on the link to see further info):
PFF60-501 Front Arm Front Bush
PFF60-501G Front Arm Front Bush, On-Car Camber Adjustable
PFF60-502 Front Arm Rear Bush
PFF60-502G Front Arm Rear Bush. Caster and Anti-lift
PFF60-503-20 Front Anti Roll Bar Bush 20mm (for Cup models and R26)
PFF60-510 Rear Beam Mounting Bush
Their is also now a gearbox mount bush:
PFF60-525 Gearbox Mounting Bush Insert
The full range can be seen here: http://www.cazanracing.co.uk/bushes-5138-c.asp
For vehicles used in Motorsport or predominately on track, these new bushes are available in the Black Series range, manufactured using Powerflex's 95 Shore A compound that boasts 25% increased stiffness over the purple 80 Shore performance material.
RSMEGANE members can get a 10% discount on our web prices by using the discount code: RSMPF10
UK mainland delivery is free. If you require black series bushes please PM me.
