How hard are the pivot/ball joints to replace on the hub carrier, is it do-able DIY?
I've done things like bushes, struts, springs before on other cars so am a pretty handy DIY mechanic, but I don't have access to a press.
Looking at it, the old ones can probably be drilled out if needs be but what about re-fitting? Is just popping the joint in the freezer over night going to shrink it enough to be able to fit into the carrier without some sort of press?
