Recommend a cheap OBD reader which works?
Has anyone bought a cheap reader which they can recommend works?
trying to avoid a 2 hour round trip to my garage to reset service light and check warning messages?
Thank you
You can get them from some where like argos fairly cheaply and they will do a job.
But if it is actually a service light you wont need to plug an obd reader in turn this off. You can do this like this video here -
It will be the same between RS and bogo clios.
great thank you will do this to the service light- now just need to plug in to read a code with my ABS.
can anyone put a link to one that worked for them?
thank you
Reactions: Tarticmonkey
I've used this one from Euros that a mate has. Nothing spectacular and you'll need to google codes but it does a job.
So from research the above OBD only reads engine faults- im specifically tracing a ABS fault so need the OBD to read all codes- what OBD reader reads all please? thank you
