Springs for 197/early 200
My 200 is a 59 plate so I've gathered I need 197 springs, but the lowest I can find is h and r 30,40... Does anyone know of any lower? Maybe 50mm Drop on the back or will I need coilovers? :smile:
Why dont you just get coilovers if you want a drop like that? Bit more expensive but if you go further than 40mm with lowering springs they cause the dampers to leak and become spongy
197/200 are the same until 2010 '10' plates
then they have the revised smaller top mounts 2010 > onwards
