I decided to take the subframe off my 197 to replaced ARB bushes and to gain access to fit proper clips on the steering rack gaiters. I'm guessing the subframe has been off before as the manifold looks like its had new flexis fitted, whoever did that obviously couldn't be arsed to refit the the wiring properly. As an example the plug for the cat was jammed between the chassis and the solid brake lines. I was hoping that somebody on here might have some photos of taken from underneath the car that show how the wiring should be routed and if possible how it fits onto/around the subframe..
