Just started this morning, in car on way to work and though "hey my fans on speed 2 and there's no air coming out, immediately suspecting heater motor failure I tried the other speeds but they all work fine, messed about with the dial (standard Cup heater controls not climate) turned to 3, 4 then 1 then back to 2, still nothing, back to 1 then 4 then 3 then 2 and 2 started working again.
Came out of work and got in car, speed 2 not working again, messed around again, nothing, tried again, working
Went home, went back out to pick the misses up from work, speed 2 working, turned car off, 5 mins later started car back up, not working again, messed around with no joy, went to Asda came back out started car and they worked right away,
Any ideas, it's obviously not the motor, nor the resistor because if it was it'd be more than 1 speed, plus it obviously works sometimes so whatever it is is intermittent
