Centre section
Edinnit
Afternoon.
Bought a 197 and its got the centre silencer removed, I'm guessing that's causing the flat spot after reading the forum.
Will the silencer have been cut out, or can I buy one from an exhaust place and bolt it back in?
The silencer is normally cut out yeah, and a replacement section of pipe welded in. If you can get hold of an OEM silencer I don't see any reason why a good exhaust place couldn't weld it back in for you.
A flat spot is there on most 197/200 even when standard, but any exhaust mod can exaggerate it. Putting a silencer back in should improve things, but there may still be a slight flat spot there :smile:
OK nice one, thanks.
Its been put in with clamps, but obviously there isn't any flanges left to bolt the standard unit too
Yea its got a sleeve with 2x u-clamps on. I want a standard really, give us as much change of a smooth flat spot as possible lol
Sent from my SM-G920F using Tapatalk
