Hi guys
Just wanted a bit of advice really. I'm not the most technically minded so please bear with me
I was at cadwell on thursday and everything was going fine until my second session when I started to press on to get some propper heat Into my brakes and tyres when I noticed that it was getting harder to select gear going both up and down the gears
I originally thought that I wasnt depressing the clutch far enough (my feet were very cold wearing my karting boots in zero degrees)
Then when I got to the and of park straight and started to scrub speed off for the 3rd gear right handed I had pretty much no hydraulic pressure from my clutch pedal and I couldn't select any gear.
I had to disengage gear and pull the the side. I pumped the clutch 10-15 times and get a bit of pedal feel back that allowed me to select a gear to limp back to the pits
After a few minutes I had a pedal back and went to try it in the road to get some fuel and all. Seemed to be ok
Went out to give someone a passenger ride after lunch and managed to get about 4 laps before the same happened again
Now the clutch itself seems fine. No slipping and when I have a pedal all functions fine.
When pressing on this is where the problem starts.
I know the clutch takes a feed from the brake reservoir and a few weeks ago I had a full brake fluid change at ktec when I had my big brakes put on. I'm thinking that there maybe a water/airlock in the system somewhere. Brakes are functioning fine. I have had no lost of fluid from the underside and the level is constant in my brake reservoir
I know its probably that but I'm gutted I lost 5 hours of track time for this
Anyone else ever had this......thoughts and comments would be appreciated
A
A
