Great :thumbup1:, and BTW Recaro's are 5kg heavier than the OEM.
i read that the recaros are 6kg lighter. im not sure if thats each or between them
A friend of mine had them weighted before he installed them in his car, and they were 5kg heavier than the OEM seats - maybe because of the heavy base of the seat?
rap.. yesterday i've a battle with my friend with ph1.. with a good power, 178bhp..
we need to remove 50kg or get other 10/15cv :biggrin:
start @ 50kph in 3rd gear.. and ph1 go go go
[/IMG]
How did you mount the dash over the rollcage bar? i'm having a right mission and i'm welding all sorts of brackets onto it!!
actually is that a custom cage? i noticed the door bars are different!!
Cut the dash round it pal!
Not as easy as that chap!! the front roll bar sits higher than the dash bar, and the dash bar won't fit in with the front roll bar.
All the brackets for the heat/air exchanger, dash itself, steering column, centre console are on the dash bar.
They ALL have to be modified and re-made to make everything fit!! its a right arsehole!
After hours of fondling i've only just managed to get the heat/air exchanger to fit.
That's the madeno 197 r20 (www.clior20.nl) it's the cup cage for sure as I asked. Might have some mods though.
nice one spinky. i love that cage. if i carry on with the clio i am definately getting one, although i like my gadgets too, so would want it to fit with full dash.
surely you can just cut the dash bar off the cage, then it just mounts down either side of the dash doesnt it?
K | Weight of stock hood, or bonnet, as you call it : ) | Clio 197 Area | 4 | |
Lightweight flywheel | Engine, Gearbox, Exhaust and Air Intake | 1 | ||
197: Clio's natural weight saving.. | Clio General Chat | 9 | ||
T | Weight Saving Ideas | Clio General Chat | 34 | |
T | You want real weight savings - money can not be a barrier! | Clio General Chat | 15 |
