Adjusting the level on 'cornering lights'
I retro fitted the projector lamp/cornering lights to my R27, but the beam on one is slightly higher than the other, which is a bit annoying!
I seem to remember reading somewhere that you can manually adjust the level with screwdriver, but I'm not sure how to go about doing this.
Can anyone help please?
Russ.
Can usually be done just by lifting the hood up. Have a look around next to the lamp units. There should be a plastic screw - this is the adjuster. Stick your thing in and twist to adjust :smile:
mate i have the same problem, let me know how you get on.
i also don't think i'm getting the full length
All you need is an allen key - if you look down on the top of the lights with the bonnet up, you'll see where to put it - just adjust as required - mine are level now :smile:
