Engine/Gearbox Mounts
Discussion in 'Engine, Gearbox, Exhaust and Air Intake' started by massivewangers, Aug 21, 2019.
  1. massivewangers
    massivewangers Paid Member
    25
    Norfolk
    Car:
    Clio 197
    Apologies, I suspect this has been asked quite a few times, but I have been searching through some old threads and not really found a definitive answer.
    I'm pretty new to 197s, so not sure on the engine/gearbox mount arrangement. My car feels like it has a bit of movement in the mounts, so I'd like to give things a freshen up. I'm seeing a few Powerflex options, but I am not sure which are the best to go for.
    The car is very much a daily driver, so I don't want to go too mad. On my old 172 Cup, I ended up with Vibratechnics engine and gearbox, then Powerflex Black in the dogbone and it was quite harsh. Fine for what that car was for, but I want something a bit more sensible this time around.
    I'm even struggling to work out how many mounts there are. There is one upper engine (in basically the same place as on the 172), one upper gearbox (again, much like the 172), then an upper torque mount, above the upper engine mount, but what others are there? I assume there is a lower anti-torque mount of some kind?
    Which ones are the most likely to go bad with age, and which are best to upgrade?
    I appreciate the help. Again, sorry if I am the 987,000th person to ask the question!
    osmanv likes this.
  2. osmanv
    osmanv
    24
    Car:
    Clio
    Had powerflex yellow on my car, I'd recommend the gearbox and bottom two mounts, the top mount I'd recommend keep stock to reduce vibration.
    On cold starts and idle my car should vibrate a lot especially on the steering wheel.
    As for the parts check the powerflex site as they have the catalog
    Sent from my CLT-L29 using Tapatalk
  3. RSRowe
    RSRowe Paid Member
    256
    Car:
    Clio 197
    massivewangers and osmanv like this.
  4. massivewangers
    25
    Norfolk
    Car:
    Clio 197
    Thanks mate, bit clearer now.
    So is it similar to 1*2 land, where the lower torque mount (20) is the one most people put poly into?
  5. RSRowe
    RSRowe Paid Member
    256
    Car:
    Clio 197
    Tbh people generally do them all, but it's certainly a good starting point.
    I've a set of yellows in mine and you can certainly feel the vibrations. It is pretty much fully stripped.... So it becomes a bit of a microphone inside.
    I'm not sure whether just the torque bush will then put more pressure on the remaining ones if that's what you decide to do.
  6. lewishunter98
    lewishunter98 Paid Member
    569
    Southampton
    Car:
    Racing Blue Clio 197
    I had 3/4 done and dailied mine and barely even noticed the vibrations. The one I left out was the main engine mount
    Though I've since done the 4th and could easily daily it still. (It became the weekend car hence why I don't) but the vibrations really aren't even that bad
  7. Lownds197
    Lownds197 Paid Member
    55
    Car:
    Clio 197
    Dogbone and upper torque on mine and the vibrations through the steering wheel when pulling off are horrific.
  8. massivewangers
    25
    Norfolk
    Car:
    Clio 197
    It's interesting how there are so many different perceptions on what is a lot and what isn't a lot of vibration. I think I will start with the dogbone and see how to go from there. Cheers guys!
    Beany and lewishunter98 like this.
  9. Mark_L
    Mark_L Platinum Member
    508
    Car:
    197 Cup
    I have them all done but have an evol dogbone mount.
    It does have a slight vibration at idle but I don't even notice it any more.
    They do get better.
    massivewangers likes this.
  • Share This Page
