Right, someone thats a mechanic! I could do with some information about the lower ball joint/ driveshaft problem I'm having.
My car is currently in the garage because it was pulling to the left when on the road. The garage has said that my lower ball joint needs to be replaced at first then when i was due to pick it up they then said an abs sensor is seized too (which i had NO light on the dash before i took it into them). Is there anyway that upon removing the sensor that the driveshaft would get damaged? is it even attached? Im told the treads have been stripped when removing the abs sensor so i now require a new driveshaft? To me (non mechanic) this seems like they have made a f**k up and trying to give me the bill!
any help/info would be much appreciated!
