Might be the reverse switch on the gearbox, pretty easy to do, I had to remove battery and the plastic cover to get to it and I think it's a 24mm socket. If you don't get the rear wiper come on when you wack it into reverse in the rain with auto-wipers on then it will be the switch but if it does come on then most likely be fuse or bulbs
