Front tyre wear - inside edges
I've noticed the tyres on the front of my 200 Cup have gone bald around the inside edges, maybe first 1.5" of tread. The tyres are generally well worn, maybe 2mm above wear indicators elsewhere, and the wear is the same on both sides of the car.
Question is, is this normal owing to negative camber or should I get the alignment looked at?
Tyres are Bridgestone RE050A, if that makes a difference.
Thanks.
it aint camber!
more than likely excessive toe-out on the front wheels - needs checking for anything bent and repaired/adjusted accordingly
